× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
I can sometimes gain access via direct connection to wired ethernet port
ngear_user_us
Follower
I am having the same problem and have had to reset three times now.
It started a couple of months ago.  I can sometimes gain access via direct connection to wired ethernet port, but the connection will drop periodically.  When it happens, I can see that no IP address is being assigned.
Only a factory reset will restore functionality.  The last time i did this, it lasted a couple of months.  The last two times, it only lasted a few hours before the problem reoccurred.
DHCP seems to be failing to wired and wireless connections.
The problem is the same with two different modems.
Router:
Netgear MR60
Modems tested:
1. Netgear LM1200
2. T-Mobile 5g Gateway
Message 1 of 2
Guru
Re: I can sometimes gain access via direct connection to wired ethernet port
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does the front LED change from BLUE to Amber when this happens?
Can you access the MRs web page at all?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 679 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
