× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Is the MR60 backward compatible with the EX6120 and/or EX6100v2?
markris85
Follower
I upgraded my home wifi network to the MR60 and satellite MS60 Nighthawk Mesh wifi-6. It so far works great with much-improved data rates and coverage.  I'm sitting here with two AC extenders, the EX6120 and EX6100v2.  I wonder if these two are compatible with the MR60 and could potentially extend my network if I ever wanted or needed to use them.  Is this possible and if so, how would I do this?  Not through the Nighthawk app, I'm assuming.   Any ideas and guidance are appreciated.
MW
Message 1 of 2
Accepted Solutions
Guru
Re: Is the MR60 backward compatible with the EX6120 and/or EX6100v2?
I presume they should work in a pinch.
Best to keep wifi sources to a minimum as there can be too much wifi signal in the home that can cause problems:
https://youtu.be/UR0viMLISz4
Would use the NH app or a wifi laptop that can connect to the EX setup web page as well.
Review the online user manual and installation guides here:
https://www.netgear.com/support/
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 969 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
