- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Local Area Network DNS failing? What causes and and thing to do besides reboot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an MK60 that is running as my router/firewall/DNS/DHCP and VPN. It has done this fine for the most part for years. Just recently (possibly tied to a firmware update but I am not sure about that) I have started having issues. About once a day but sometimes more the DNS part of the router is just dying. The DHCP is working, and the firewall is working. If I go somewhere based on IP that works and I know I have inbound traffic that works. My only issue is internal DNS fails and the only way I know how to fix it is to reboot. The only issue with rebooting it is that kills the inbound traffic.
One of the tests I can do when this happens is open a cmd prompt on my system and enter nslookup. The IP comes up with my internal Netgear and when I type www.google.com it times out in giving a response. When still in nslookup I type "server 1.1.1.1" then type www.google.com it responds. This is because I am sending the DNS request through the internet to Cloudflare DNS servers. In this case, I know my Internet is working well.
I am manually overriding my Internet DNS servers as I have had problems with my ISP getting DoS on their DNS servers. My primary is 1.1.1.1 and I set my second to the primary DNS on my ISP.
This has been bugging me a lot the last 4-5 days with reboots at least once a day and one day I think it was 6 times. Each time it was the internal DNS that was failing.
Does anyone have any ideas for me? Is there a way I can ssh into the MK60 and check the running servers or get a more detailed DNS server log file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Local Area Network DNS failing? What causes and and thing to do besides reboot?
Not sure why the text is so broekn up in my first post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had it happen again and I started looking through my logs when I saw that someone was trying to get into my openvpn from Australia. I am in the US so this is a little fishy. I disabled my VPN service and the last time I did this DNS started working without a reboot. I will keep updating to see if this really resolved the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It has been over 24 hours and my DNS has stayed up correctly so I am starting to think that the issue was the constant OpenVPN brute force that was trying to happen. With OpenVPN off no more issues. I think I will only update this ticket in case I see a change. Hope my posts might be useful to someone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
