Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MK63S not showing devices
russellwhite
Tutor
I have an MK63S with two satellites. When I look for connected devices either on the Nighthawk app or via a web browser, none of the connected devices show up. They are all on firmware version 1.1.7.134
Message 1 of 6
Accepted Solutions
Guru
Re: MK63S not showing devices
It could be with it being a new system that it upgraded several versions of firmware. Sometimes updates are helpful with a factory reset. Might be worth trying.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 6 of 6
All Replies
Guru
What modem/gateway is the router connected to?
Are you using a switch for the satellites or are they wireless?
Did you try a reboot or factory reset?
Message 2 of 6
russellwhite
Tutor
Connected to a Netgear cable modem CM1150V No switch, the satellites are wireless (is a Mesh wifi system). I have not tried a factory reset because I just set them up yesterday.
Message 3 of 6
Showing up where:
  • Mobile app?
  • Browser graphical user interface (GUI)?
This is a good alternative for Windows and Macs:
genie | Product | Support | NETGEAR
Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress and install.
Netgear is trying to kill this useful utility.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 4 of 6
russellwhite
Tutor
That was in the original message.  Both the app and the browser show 0 connected devices.
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1538 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
