Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MK83 Lowers internet speed
DougDePew
So I have this lovely MK83 mesh setup, which seemed happy for a while.  However, lately I have noticed that the speed (internet side) drops back to around 100MB, where the service is 400MB.  If I reboot the router, the 400 is back for some period of time.
It's not internet-side, using an older router never experiences this.
Firmware is current, cabling is good, occurs wired or wireless.
Since it's past the 90 support window, I'm here.  And getting close to taking $300 to the trash, which is always a lovely thing to do after having it since May.
Message 1 of 12
Guru
Re: MK83 Lowers internet speed
Are you speed testing with a wired PC or wireless device?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
Message 2 of 12
DougDePew
As I noted, it is wired or wireless.  Not an issue with that.
MR80, F/W 1.1.6.6_3.1.93
Spectrum E31T2V2
Satellites are eliminated from the equation.  Wireless test is from within 10' of router.
No other wireless channel overlaps, but with the issue also on wired, not a concern again.
Message 3 of 12
Guru
Is Armor enabled by chance?
Has a factory reset and setup from scratch been performed since last update?
Spectrum E31T2V2
Message 4 of 12
DougDePew
No Armor involved, and resets (2) have not had any impact.
Message 5 of 12
Guru
What speeds do you see with a wired PC?
What wireless device are you speed testing with?
Message 6 of 12
DougDePew
With a fresh router reboot, 430ish.  Same as wireless after restart.  At some random interval later, wired and wireless struggle to attain 100, usually high 80's.  Fresh router restart, 400+ is back.
Speed tests performed with a phone, a tablet, 3 laptops.  All matching results.
Message 7 of 12
Guru
So if this falls off and speeds get slower, I would probably return this system and get another or something else. Seems like the speeds should maintain with out seeing any speed reduction.
Message 8 of 12
DougDePew
Exactly.  Less than 6 months old.  Basically junk, not even really wanting to replace it.  Just jumk $300 and start anew.
Message 9 of 12
Guru
Can you take it back to the place of purchase?
I'd contact NG support to see what your options are....
Message 10 of 12
DougDePew
Well past return date.  Solution achieved - it left the house this morning in the back of a Waste Management truck.
Message 11 of 12
Guru
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1882 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
