× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 Address Reservation updates are lost after reboot !!
DevendraS
Hi There,
I have a MR60 router with 2 MS60 satellites. Firmware was upgrade just today to V1.1.6.124_2.0.59 so I am not sure if that has caused the following issue.
I need to have some 42 MAC addresses in Address Reservation. I remember very clearly that I had changed one entry (device name changed) and added two entries (two new devices on the network) last week.
The changes were working fine after "Apply" as all the devices were started after a day or two so I did not reboot the router at that time.
Now that the router got rebooted after firmware update those 2 new entries are gone from the address reservation and the one changed entry is back to what it was before (old device name) !!
I tried the update entry and add two entries again now and it works / shows the updates till I don't reboot the router, however after reboot the entries are gone again. I did this two times just to be sure and both times entries are going a back to what they were before !!!
Just to try other changes I changed the DNS settings on the Router from "Get Automatically from ISP" to "Use These DNS Servers" (and changed the default proposal to 8.8.8.8) and after reboot even this setting went back to "Get Automatically from ISP" !!
Am I missing something here while making the changes ? I am definitely clicking on Apply every time.
Or the router is simply not accepting any changes to the config that existed before a certain time ? (May be before the Firmware was updated?)
Please help me find a solution for this issue as one of the new devices I am trying to add is a Raspberry PI with PiHole to have my own DNS !!
Thanks
Devendra
Message 1 of 5
Accepted Solutions
EternalStudent
Apprentice
Re: MR60 Address Reservation updates are lost after reboot !!
"after firmware update"
I've had things go weird after firmware updates.  I've read time and again that it's a best practice to factory reset after a router firmware update, then reconfigure your device as needed.  Similar to BIOS updates.  I assume because they don't test migrating all possible settings, but they do test if applying new settings from a reset state works well.
Some people mentioned doing a setting backup, then restore...but that seems like taking the same old (possibly bad/wrong) settings and reapplying them.  So I tend to just manually configure things again if I try this step.
This is one reason I haven't tried to whitelist my devices as you seem to be doing.  Yes it'd give a bit of extra protection from someone else using your network (unless they copy an existing MAC address), but I'd think a good wifi password + high WPA setting (3 or 2-AES) should protect you fairly well too.  But I'm not an expert.
Message 2 of 5
All Replies
EternalStudent
Apprentice
Message 2 of 5
DevendraS
Hello EternalStudent,
Thanks for your reply.
After reading a lot posts I too was wondering if I need to reset and start over after the firmware update. The only thought that stopped me so far was, what if it does not work even after reset and repeat set up ? The process will easily take me a few hours and wanted someone who has had same/similar problem as mine to confirm if the reset / repeat setup fixed it for them.
It loos like this, being a best practice, is my only option at this time. So I am going to give it a try.
Thanks
Devendra
Message 3 of 5
Guru
Did you try a full factory reset and setup from scratch after the FW was updated on the MS and MR?
I recommend you back up the MRs configuration to file for safe keeping as well:
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Message 4 of 5
DevendraS
So the full factory reset and setup from scratch worked. It took me couple of hours to get all the settings back but had no other choice.
I am now able to change the settings and even after a restart I do not loose them. Pi-Hole is now my DNS ... no more ads !!
Thanks for all your help @EternalStudent and @FURRYe38
-Devendra
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2466 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
