Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 Guest Network isolation
uhcax30
I have MR60 and two satellites connected to a CAX30. The MR60 acts as a Router.  I am not able to isolate Guest network from internal network. I do not see any option to block guest network from seeing internal network.
Message 1 of 6
Accepted Solutions
Guru
Re: MR60 Guest Network isolation
I'll see if I can find out if this is expected behavior. As long as you can't access those device, should ok.
Message 6 of 6
All Replies
Guru
How are you determining this?
What FW version is loaded on the MK60 system?
Message 2 of 6
uhcax30
I am able to scan the network and see every device on the network.
I am running the latest version of firmware on both MR60 and MS60s.
Message 3 of 6
Guru
Can you access any of the devices from the guest side?
I saw my Wired Windows 10 PC on my Mac Book that was connected on the GN. However I could not access it's shared folders. When i changed the Mac Book to the main wifi network, I could then access the shared folders.
Message 4 of 6
uhcax30
Yes you are right. I was not able to access any services. However I was able to scan the network and view which all devices existed
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1611 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
