× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 dhcp errors
posttrad
Tutor
MR60 dhcp errors
Been having a lot of trouble with this router going offline and only being able to come back after a reset. some devices will reconnect but most give dhcp errors. I sometimes have to reset the router multiple times over the course of hours just to be able to access the admin page. I also can’t change the name or password from default otherwise no devices will connect.
I called support but I’m past 90 day warranty for phone support had this router for less than a year but I’m at the end of my rope, wondering if I should just buy a new router
Message 1 of 7
Guru
Re: MR60 dhcp errors
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 2 of 7
posttrad
Tutor
Factory reset firmware
Spectrum modem not sure of the model #
Using Lan cable that came in the box
Sometimes turning Qos on will help for a few days. Not sure if that matters. Also when connected to a MacBook I can only access a few websites while others say server not responding
Message 3 of 7
Guru
What Firmware version is currently loaded on the MK system?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Can you look at the front or back for any printing or sticker information?
Message 4 of 7
posttrad
Tutor
Modem is EN2251 hitron
I can’t currently connect to the admin page to check firmware. Currently restarting/ resetting until I can get a connection on at least one device.
Message 5 of 7
Guru
Can you disconnnect the MR from the modem and connect 1 wired PC to the MR and factory reset the MR and walk thru the setup wizard with the PC and web browser at 192.168.1.1?
Message 6 of 7
Guru
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1655 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
