× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60
AH_1876
Follower
MR60
Bij het opstarten/updaten van de MR60 werd de internetverbinding onderbroken. Nu blijft de LED wit knipperen. De voeding verwijderen en opnieuw aansluiten bracht geen oplossing. De resetknop achteraan 7 seconden indrukken en heropstarten bracht geen oplossing. Ik kan geen verbinding maken met de router om handmatig de firmware te herstellen. wie kan me helpen ?
TRANSLATION : The internet connection was interrupted when starting/updating the MR60. Now the LED continues to flash white. Removing the power supply and reconnecting it did not solve the problem. Pressing the reset button at the back for 7 seconds and restarting did not solve the problem. I cannot connect to the router to manually restore the firmware. Who can help me
Message 1 of 3
Re: MR60
There is more severe, recovery reset, that you could try:
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
Message 2 of 3
Guru
Re: MR60
Any progress on this?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 568 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
