× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR70-MS70 one satellite unit will no longer connect
lgrekstas
Follower
Mesh has one base unit (MR70) and 2 satellite units (MS70).  One satellite unit connects successfully but second unit will not connect.  System was working fine, until suddenly second unit no longer connects/syncs to base unit.  I direct connected second satellite unit via ethernet and units seemed to sync up, but as soon as units went into wireless mode the satellite unit lost connectivity even though it was set directly near the base unit.
Does this mean the unit is bad and I need to replace the mesh system?
Message 1 of 2
Guru
Re: MR70-MS70 one satellite unit will no longer connect
Does the one MS connect wirelessly with the other MS turned OFF?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 📡 ‌‌🛰
What channel configurations are currently set on the router?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 802 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
