- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR80 and 4 satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I setup a MR80 latest firmware with 2 satellites. Using Windows and IOS.
I needed to add another satellite which I just purchased. The new satellite has a different SSID and username password. It did connect and it works BUT it's a bit wonky. iPads connected to it seems to always want to connect to the MR80 and the original satellites even though they are really at the edge of range which is why I got the additional satellite to begin with. Is there something I'm supposed to do with the new one that I didn't do right?. I can't seem to find anything in the documentation or on this forum. Thanks
Steve
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR80 and 4 satellites
Its up to the devices themselves (phone/tablet/computer) to decide which satellite or router to connect to based off their own roaming protocols. The satellites/router don't actually control that.
What you can do on your end is make sure the router/satellites are at least 30 ft apart.
That'll help with roaming.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before connecting the new satellite, do a Factory Reset on it. i.e. hold a tiny object such as the end of a paperclip or a SIM card ejector in that tiny hold next to the power switch labeled "Reset" until the power LED turns amber and begins to flash. When connected to the primary system, it should broadcast the primary WiFi name and use the primary WiFi password. (and other networks if you have them, such as Guest, IoT, Employee, etc.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank You, I can't try until tomorrow, I'll let you know how it works out.
