blkhk1up
Sep 18, 2022Follower
MR80 with Satellite Remote reboot Satellite failure
i have the MR80 (V1.1.6.6_3.1.93) with 2 wireless Satellite's, i am required to reboot remotely for unrelated device issues. However, i need to do this often remotely (away from the building) when i do the successful Router reboot, i loose the wireless Satellite's. i have to manually return to the building and manually reboot (unplug and plug) or the wireless Satellite's to reconnect to the Main Router...................
FYI: the Satellite's are not wired. this is a wireless connection. we are unable to run a CAT line to either Satellite's
what is the sequence to reboot the router and Satellite's logically without physical interaction?
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?If you have the Nighthawk mobile app connected properly you can reboot the MR remotely while your not connected locally.
Might update FW as well. Update the MS first, then the MR lastly:
