× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Mesh M60 reset not working. The app does not recognize the router and I am unable to reset to factor
M1sajal
Follower
I lost power and have been trying to restart M60 Mesh network, nothing works (reset via www.router, holding reset button) when I scan the code, the app recognizes the network but does not see that my phone is connected to same network! I have attempted 6x and am so flustered! Any help??
Message 1 of 2
Re: Mesh M60 reset not working. The app does not recognize the router and I am unable to reset to fa
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
  • Turn off and unplug modem.
  • Turn off router and computers.
  • Plug in and turn on modem. Wait 2 minutes for it to connect.
  • Turn on the router and wait 2 minutes for it to connect.
  • Turn on computers and rest of network.
If you can do it, you could try using the browser graphical user interface (GUI) to set up the router.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manually set up the Internet connection.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 848 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
