Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Mesh Mr60 router doesn't work and cannot be updated with the firmware
petercreate
Tutor
Hi,
I've tried reset and other reset methods I can find. Also, I tried the method introduced here, https://kb.netgear.com/000064624/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-on-Apple-m... . The last msg on the terminal is "Transfer timed out". I tried it times and get the same result.
It seems that the new firmware cannot be uploaded to the router.
Regards, Peter
I posted the information from the Mac OS terminal here,
Last login: Tue Oct 25 11:32:10 on ttys000
(base) jx@jx-MacBook-Air ~ % cd /Users/jx/Desktop/MR60-V1.1.7.132_2.0.64
(base) jx@jx-MacBook-Air MR60-V1.1.7.132_2.0.64 % tftp 192.168.1.1
tftp> binary
tftp> put MR60-V1.1.7.132_2.0.64.chk
Transfer timed out.
tftp>
Message 1 of 7
Accepted Solutions
Guru
Re: Mesh Mr60 router doesn't work and cannot be updated with the firmware
Glad you got it figured out 🙂
Might mark it solved so others aren't still trying to fix it
Message 4 of 7
All Replies
Guru
what firmware version are you on?
Is the router working and it just won't update its firmware?
Message 2 of 7
petercreate
Tutor
Hi Plemans, thank you for your reply. It's working well now after a successful updating the firmware. Previously I connected the router via its Internet sock instead of the Ethernet sock, which was the reason the updating didn't work.
Message 3 of 7
Guru
Message 4 of 7
petercreate
Tutor
Thank you. Don't know where to mark it, just sending a kudo with your message.
Message 5 of 7
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Message 6 of 7
petercreate
Tutor
Thank FURRYe38. Have that done. 🙂
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1415 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
