Dec 19, 2023Guru - Experienced User
NOTICE: Nighthawk MK Series MESH System Compatibility Information.
NETGEAR only supports same model MESH systems with in each model SKU going forward.
MK60 series only supports MR60 and MS60 series
MK70 series only supports MR70 and MS70 series
MK80 series only supports MR80 and MS80 series
MK90 series only supports MR90 and MS90 series
NETGEAR does not support cross model series between each model SKUs.
In reference to a NETGEAR KB article in regards to what MK MESH models were compatible, the following link was removed and discontinued by NG 12/2023:
kb.netgear.com/000063029/Which-Nighthawk-Mesh-products-are-compatible-with-the-Nighthawk-Tri-band-Mesh-WiFi-6-products
Link is no longer valid or working.
Thank you.
