- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NetGear MR60 - SSH connection from Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have Nighthawk® Mesh WiFi 6 System MK62. Router + satellite (connected via wire). Both running on latest firmware: MR60-V1.1.6.124_2.0.59.
I use SSH connection inside my LAN to connect to my Raspberry Pi and NAS storage. All is working fine. However I can't connect from outside my LAN - from Internet. SSH connection always time-out.
I double checked Port forwarding rules (IP addresses and ports to connect to LAN devices): O.K.
Tried to connect to router using Dynamic DNS address and external IP address - nothing helps.
It seems that SSH connection is blocked when it comes from WAN. Is there any help for me? I do really want to use SSH connection..
Thanks for any suggestions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NetGear MR60 - SSH connection from Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Adding info for my Internet connection:
I have FTTH connection to my home.
First device is: TP-LINK MC220L which is a media converter of SFP to RJ45. From this TP-LINK goes wire to my Mesh Netgear router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you disable uPnP on the MR before or after setting up any Port Forwarding rules?
Is any SPC or Armor enabled on the MR as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for pointing me to the directions that might be the cause of the problem.
Info:
there are no parental controls nor Armor protection enabled. I also didn't apply any Static Routes, VLan/Bridge settings. IP6 is also disabled.
Port Forwarding rules were applied first and after that I noticed uPnP so I disabled UPnP in second step. I rebooted MR60 afterwards.
