Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Netgear not honoring their hardware warranty!!!!!
NetworkGuy1490
Apprentice
I have had an open case with L2 for almost 3 months about the frequest disconnects of the MR60 Mesh router. About two months ago, I used a WiFi monitor and saw there where only three access point. (The 5Ghz was missing from the satellite.) Dispite repeated requests for a HARDWARE replacement under the one-year warrany. (Mu system is now 5 months old) they keep finding excuses to not send me a replacement.
This is the nonsense they asked me to do,
Can you help perform and check the following:
1. Can we connect a device to 5GHz .
2. Then open the router's GUI. Check the Attached Devices and see where the device is connected
3. Make sure that the client/device is close to the satellite so that it would connect to it.
4. Do you have an AX client? It would be better to use that in this testing.
Angel
NETGEAR Support
Instead I used a WiFi monitor to show the connection standing next to the router, midway, and next to the satellite. It clears shows the 5Ghz/router connection, then the 2.4Ghz/router connection, but standing 5 feet away from the satellite it only connects at 52.4Ghz.
I have send mutiple screenshots from multiple apps and they still keep playing games. It took them over 3 weeks to even acknowledge I had opened a BBB complaint.
I wonder if there are enough people for a class action suit?
Message 1 of 3
schumaku
Guru
Re: Netgear not honoring their hardware warranty!!!!!
Lengthy thread in the community does reflect this.
Either they are able to remote diagnostic and fix (if a firmware/config issue), or this is a hardware issue on your Nightawk Mesh satallite.
This reads to me like 1st level support is totally overrun by the "complexity" of a simple consumer mesh system.
@arunkmony your business, your responsibility.
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hi NetworkGuy1490 - I've responded to your private message.
Christian
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1624 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
