Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
New - MR60 / MS60 Firmware Version 1.1.7.134 Released
Guru
New Features and Enhancements: 1/02/2022
  • Fixed security issues.
  • Fixed NH APP might show 'Router not Found' and 'Login Required' messages during on-boarding which blocks the on-boarding installation.
  • Fixed offline satellite display issue on iOS APP.
Download Link:
https://www.netgear.com/support/product/mk62.aspx#download
Installation Instructions:
  1. Download the firmware to a convenient place such as your desktop.
  2. Log in to the router using http://routerlogin.net
  3. Click the ADVANCED tab.
  4. Click Administration.
  5. Click Router Update.
  6. Click the Manual Update tab.
  7. Select satellite first and a new web page pops up. Please browse the new satellite firmware and upgrade satellite firmware first.
  8. After you finish the satellite firmware upgrade, please find “Locate and select the upgrade file on your disk” on the MR60 web GUI and click “Browse” and locate the file you just downloaded.
  9. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
  10. The router reboots when the upgrade is complete. After the router boots up and the LED becomes steady blue.
To check that the upgrade was successful, log in to the router again at http://routerlogin.net and check the firmware version.
If you manually update, be sure to update the MS first, then MR lastly.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Update the MS first, then the MR lastly. After the FW files are loaded and the MS and MR are ready, power OFF the MS and MR for 2 minutes then back ON.
Unplug the power adapters from the power wall outlet.
NOTE: A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you. Please leave feed back in this thread.
Message 1 of 2
Guru
Re: New - MR60 / MS60 Firmware Version 1.1.7.134 Released
Ran a quick test with my MR60 as host router connected to my CAX80 in modem only mode.
Speeds look good for Apple iOS 16.2 and Android OS v12 on this version of FW:
Manual channel 11 and 149.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4929 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 7
