× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
New - MR90 / MS90 Firmware Version 1.0.1.36 Released
Guru
New Features and Enhancements:  09/14/2023
  • Fix Memory leakage
  • Improve WiFi Backhaul and Steering stability.
Download Links:
https://www.netgear.com/support/product/mk93s#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documenta...
Installation Instructions:
Download the firmware to a convenient place such as your desktop.
Be sure to update all MS first, then the MR lastly.
NOTE: If a problem is seen after applying this FW update, try powering OFF the ISP modem, MR and MS units for 1 minute then back ON. Last resort would be to try a full on Factory Reset and setup from scratch.
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
This article applies to:
Nighthawk WiFi Systems (3)
Let us know how it works for you in this thread...
Message 1 of 2
Guru
Re: New - MR90 / MS90 Firmware Version 1.0.1.36 Released
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1248 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi 770 Series
