Sep 13, 2023Guru - Experienced User
New - Nighthawk MK93 WiFi 6E MESH System Announced
Technical specifications:
- Fast, reliable speeds: Total wireless speeds of up to 5.7Gbps make for smoother
Ultra HD 4K streaming. - Latest WiFi 6E Technology: WiFi 6E provides 50% faster speeds & double the device
capacity for MK93S compared to the previous WiFi 6 product. Experience greater speed, ultra-low latency, & more bandwidth with the new 6GHz band. - Super-fast Tri-band WiFi: NETGEAR Tri-band technology ensures max speeds for up to 100 connected devices to keep up with your family’s streaming, gaming, & smart home needs. Plus, with our customized WiFi, you can enable a 2.4GHz WiFi connection solely for your IoT devices.
- Powerful Quad-core Processor: More processing power increases the overall performance of your network.
- More Wired Connections: Seven Ethernet ports for your gaming console & IoT gateway wired connections. Boost your wired speeds up to 2Gbps† by linking two LAN ports together–ideal for network storage.
- Fast Multi-Gig Internet: Get today’s fastest Internet with the up to 2.5Gbps† Internet port for your most demanding tech products—such as game consoles, streaming players, & computers.
- Ease of use: Easy setup with the Nighthawk app, customize and enjoy your new Nighthawk Mesh WiFi in minutes.
https://www.netgear.com/hub/pressroom/netgear-brings-mk93/
Product Support Page:
