× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Night Hawk MR80 Slow WiFi
bulldog00
Apprentice
I am experiencing the same issue with my MR80/MS80 setup.  I did not have this issue previous to the current FW push of 1.1.7.xx.
I have tried all kinds of troubleshooting, factory resets, and even have the MS80's wired backhaul.  I did not have this issue on the satellites previously and after all troubleshooting, i believe the issue is FW related.  Unfortunately, Netgear doesnt allow users to disable "auto updates" for the firmware on the MR80 series.
Message 1 of 19
Guru
Re: Night Hawk MR80 Slow WiFi
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 🛰
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What speeds do you see at the MR when the MS are turned OFF?
What wireless devices are you testing with?
Do wired speeds reporting same results?
Message 2 of 19
bulldog00
Apprentice
The Latest available- 1.1.7.12
Cannot disable automatic updates for the FW.
Netgear CM1100; Xfinity
Quality CAT6 cable is used between Modem and NG.
2300 SQ FT
What is the distance between the router and satelite
30ft. Issue did not occur with previous firmware version.
Channel 1 for 2.4
Channel 44 for 5
Have tried alternate channels and scanned for interference.  No interference.
MR Speeds are consistently around 680-700mbs of wireless; hardwired is around 940mbps.
I have a plethora of devices being an IT professional,
Wired speeds are noticeable faster.
Also worth Noting that through the netgear application, checking the device that is connected to the MS, even though the device is connected to the 5GHz band, the link rate is significantly low.  Currently the link rate of a device connected is 211Mbps.
Message 3 of 19
Guru
Can you post screen captures of the MS connection rates and devices connected to the MS.
Did you do a full factory reset and both MS and MR and setup from scratch?
Message 4 of 19
bulldog00
Apprentice
Full reset was done on both MR and MS.
Here is a screenshot of the MS i am currently connected to.  You can see there are only a handful of devices and you can also see the link rate i was referring to.  ms_connected.jpg
Here is a screenshot of a current speedtest.  It seems that the upload is accurate; only the download speeds are consistently considerably slow. speedtest.png
The latest (recent firmware) release notes state that a bug fix was in place for:
  • Fixes the issue where the satellite fronthaul is down after switching to the 5G channel from the router
Wonder if this "fix" is actually causing issues.
Message 5 of 19
Guru
Thank you for posting this.
Does the prior version of FW not have the disable Auto Updates for the system?
Anything is possible on this. I've passed this onto NG for review.
Message 6 of 19
bulldog00
Apprentice
No previous FW version gives the option to disable automatic firmware updates.
Message 7 of 19
Guru
Wanna go back to that one and confirm that you don't see this issue? Please post screen capture for this if you do.
I might as well use what works best for you.
Message 8 of 19
bulldog00
Apprentice
Performed a manual FW Downgrade to the previous version (1.1.6.14).  It is confirmed that the issue is resolved in the previous FW version. You can see from the screenshots that the link rate is correct, the Download speed is corrected, and the FW is previous version.
Users do not have the ability to turn off auto update on this Router series; so overnight the FW will automatically upgrade and the issue will begin tomorrow. downgrade_speedtest.pngdowngrade_firmware.jpgdowngrade_link rate.jpg
Message 9 of 19
Guru
Great. Thank you for the info.
Keep this version of FW loaded for now.
I'll pass this on to NG.
Message 10 of 19
bulldog00
Apprentice
i will do. But it will only be this version for today; unless i manually downgrade every day.
Thank you for escalating this to NG; it seems it effects others (not just the MR80/MS80).
And if you could bring up the issue of users not able to turn off auto updating of the FW, that would be greatly appreciated.
Message 11 of 19
Guru
Message 12 of 19
Guru
Message 13 of 19
bulldog00
Apprentice
It doesn’t detail anything in the bug fixes to indicate it resolved that particular issue. And it’s kind of a pain to keep jumping back on FW to test; I’d rather netgear just fix the issue or test themselves rather than me playing scrabble to find a FW that works appropriately.
Message 14 of 19
Guru
So NG is recommending you update to newer FW. NG isn't seeing issues in this regards to slow wifi, however mentioned there is improvements with in the FW and a fix in regards to channel width. So this may have been one issue. They also suggest placement and distances between the MR and MS should be looked at. Maybe move the MS a bit closer to the MR?
Up to you though.
Message 15 of 19
bulldog00
Apprentice
I appreciate the help! It looks like the channel width correction was only in the 2.4 band in regards to 20/40 coexistence. Shouldn’t affect the speeds on 5ghz connections.
I have 1 MR wired and 1 wireless; the wireless one is pretty close to the MR and close enough to connect on the 5ghz band.
I’ll give the update a shot eventually, just tied up right this moment.
Message 16 of 19
Guru
What is the distance between the MR and MS? 30 feet should be starting...Depending upon building materials.
Message 17 of 19
bulldog00
Apprentice
Right around 30ft. That AP I wasn’t connecting to at all when doing tests though.
Message 18 of 19
bulldog00
Apprentice
Download Speed seems to be much better (improved) with the new firmware. Will give it a few days for further testing.
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 4224 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
