×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
NightHawk MK63 generating a lot of traffic
Bingoig11
Star
Hi there,
I've noticed in the logs of my firewall, that both MR60 and MS60 are generating a huge amount of traffic to netgear.com domain.
This doesn't affect the bandwidth available as this is ICMP traffic but it generates a lot of useless noise in the logs.
I want to avoid not logging this traffic, but I'd like to understand why this traffic?
Thanks,
Message 1 of 28
Bingoig11
Star
Re: NightHawk MK63 generating a lot of traffic
No one?
Message 2 of 28
Bingoig11
Star
No one is able to explain why it needs to send 1 ping per second all the time? Surprising...
Message 3 of 28
Christian_R
NETGEAR Employee Retired
Hi Bingoig11,
You may reach out to our support team with the logs for further feedback.
https://www.netgear.com/support/contact.aspx
Christian
Message 4 of 28
Bingoig11
Star
Hi,
This is what I've done Indeed.
Message 5 of 28
Mattse
Guide
I think i posted exyctly the same question (https://community.netgear.com/t5/Nighthawk-Mesh-System/MS60-Satellites-generates-a-lot-of-traffic-to...)
@Bingoig11 do you have som news about it?
Message 6 of 28
Bingoig11
Star
I received an answer from support who submitted the issue to engineering who confirmed that this is a bug.
It should be resolved in next firmware but no release date communicated.
Message 7 of 28
Mini4x
Tutor
Months later still happenig. Anyone hear anything?
Message 8 of 28
Bingoig11
Star
I've reopened a case to get feedback on a new firmware.
Unfortunately, still no ETA...
7.000.000 requests on my side, really noisy and annoying...
Message 9 of 28
Mattse
Guide
Hello @netgear
we are still wating for the firmware...
Message 10 of 28
Bingoig11
Star
I'm fed up waiting for this firmware...
Thinking about replacing the Nighthawk with another not Netgear mesh system...
Message 11 of 28
Mini4x
Tutor
Same - this is unacceptable, phonein ghome 90,000 times every 24 hours isn't a small bug.
Netgear support also closed my ticket and since my 30 days was up won't allow me to reopen or create a new case.
Last time I buy anythign Netgear.
Message 12 of 28
Bingoig11
Star
DNS Queries only for ICMP...
@netgear seriously???
Message 13 of 28
Mini4x
Tutor
Mine is hitting
www.netgear.com
devicelocation.ngxcld.com
time.nst.gov (set me time server to this for testing)
Roughly 85,000 times a day, bith my MR60 and MS60 are doing this, i've tried going back a few veriosn of the firmware and still doing it.
Message 14 of 28
Christian_R
Hello Mini4x & Bingoig11,
May you send me a private message with your email address and case number(s) and I can look into this further.
Thanks,
Christian
Message 15 of 28
Bingoig11
Star
No news, no update, no new firmware...
Think the mesh will be removed and replaced with another solution.
Message 16 of 28
schumaku
Guru
@Christian_R appears the DNS resolver code in place does not do any caching, otherwise it would not query the DNS again for the default TTL, which is 86400 secs (1 day) for www.netgear.com [resp. default TTL = 900 (15 mins) for netgear.com SOA].
Message 17 of 28
Mini4x
Tutor
Th ebig question is why does it NEED to make 80,000 requests a day? I've blocked mine at this point, and am probably going with a Ubiquity setup instead this is just too much.
Message 18 of 28
schumaku
Guru
What ever the design intention is to do some Internet connection test every or every other second - this is what is _really_ going on there. But this implementation is multiplying the traffic .... DNS query .... ICMP .... both can't be right.
Message 19 of 28
Mini4x
Tutor
It's also hitting NTP every second.
Clearly no need for this.
Message 20 of 28
schumaku
Guru
Just again this **** DNS or real NTP trafic?
Message 21 of 28
Mini4x
Tutor
Not sure, it's in ym PiHole logs hitting 3-4 hosts 85.000 times a day.
Tell me any valid reason this should do this?
Message 22 of 28
Mattse
Guide
Still no new firmware - Why?!?
Message 23 of 28
schumaku
Guru
Wating for something pushed for a live update? -> MR60 / MS60 Firmware Version 1.0.6.112 - Hot Fix available for a few days already.
Message 24 of 28
Bingoig11
Star
Just deployed the fix on router and satellites.
Seems that constant requests are stopped but will monitor it tomorrow.
Message 25 of 28
Discussion stats
  • 27 replies
  • 4283 views
  • 10 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
