Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk MK63S Satellite unit down.
NewTexan
Follower
Have 1 satellite unit that will not sync up with Router. Other satellite has no problem. Tried to reset, to reboot, to resync. Unit is 6 months old. Any ideas?
Thanks
Message 1 of 3
Guru
Re: Nighthawk MK63S Satellite unit down.
What happens if you ethernet connect the MS to the back of the MR?
Be sure that save version of FW that the MR has is on the MS. Update any MS first then MR lastly.
What version of FW is loaded currently?
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Discussion stats
  • 2 replies
  • 629 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
