× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk MR60 and Ethernet Reset
Azcal
It seems I have to reset my Ethernet adapter sometimes 4 times a day since I installed my NH MR60. The wireless system works fine other than the Ethernet reset. Have others experienced this?
Thanks,
Message 1 of 4
Accepted Solutions
Azcal
Re: Nighthawk MR60 and Ethernet Reset
Thanks. It has been some time since I spent worked on the Nighthawk and remembering how much trouble I had setting it up, I will just continue to reset the adapter. But thank you for your fast response..
Message 3 of 4
All Replies
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does this happen with any other ethernet devices?
What brand and model# ethernet adapter or device do you have connected to the MR?
Ensure any ethernet adapter drivers are updated from the mfr of the adapter.
Try a different adapter.
Does same thing happen if connected to the MS satellite?
Message 2 of 4
Azcal
Message 3 of 4
Guru
Giving feedback to the questions presented can help us as well give you more information.
Others are not seeing this so this kind of points to a ethernet adapter issue.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1783 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
