Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk Mesh WiFi 6 System With Tri-Band is here!
Dustin_V
NETGEAR Employee Retired
NETGEAR is excited to introduce the latest high-performance member of the Nighthawk Mesh System family, the Nighthawk MK83 Tri-band Mesh WiFi 6 System. The Nighthawk MK83 pairs NETGEAR's award-winning and powerful mesh WiFi 6 along with Tri-band technology. The newest Nighthawk Mesh System is designed to blanket your entire home with coverage up to 6,750 sq ft. and 4X the connected capacity than WiFi 5. Ideal for the growing smart home of today and tomorrow, the Nighthawk Tri-band Mesh WiFi 6 System is perfect for more streaming, gaming, browsing, school, work, or play!
The Nighthawk MK83 Tri-band Mesh System comes with two high-powered satellites to ensure maximum coverage throughout your home. With NETGEAR's Tri-band technology, the MK83 delivers blazing-fast speeds up to 3.2 Gbps, to every device, for lag-free gaming and smooth streaming without any interruptions. If additional coverage is needed, you can easily expand your Nighthawk Mesh WiFi 6 System by adding more satellites for extended reach.
Through the Nighthawk App, you are able to easily set up and manage your home's WiFi with features like Device Manager, Network Map, Speed Test, WiFi Settings, Guest WiFi and more! Additionally, you can protect your entire network and keep your private data safe from online threats with NETGEAR Armor.
To learn more about the Nighthawk Tri-band Mesh WiFi 6 System, CLICK HERE
Message 1 of 3
Guru
Re: Nighthawk Mesh WiFi 6 System With Tri-Band is here!
Proceedure to Manually Firmware Update Orbi and Nighthawk Mesh systems.
Message 2 of 3
Guru
Wrote up manual Factory Reset  proceedure that should work for all Nighthaek MK series mesh systems. If and when it's needed.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 31023 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
