- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Nighthawk Mesh Wifi 6 Router MR60 Dropping Satellite Connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just purchased this about a week ago. For the first couple of days, was having the same issue as everyone else here, but since assigning the satellites static IPs, it has been rock solid. The other thing I did (as a result of having issues with my Sonos) was changed the wireless channels for both 5gHz and 2.4gHz, based on what the Wifi analytics (in the app) told me were the best channels to use. I doubt changing the channels did anything, but assigning the static IPs sure seemed to help (as suggested by another user). Just wanted to post this, to confirm what others had suggested.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk Mesh Wifi 6 Router MR60 Dropping Satellite Connections
I been having numerous drops being hardwired in and through wifi.
How did you assign the satellites static IPs? Throught the Nighthawk app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can assigned IP address reservations for the MS on the MRs web page using a PC or Laptop and a web browser connected to the MRs web page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for such a quick reply!!
Sorry, but is there anyway you can reword that? Would this be going into routerlogin.com ?
I am very amatuer to this type of stuff.
Much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes log into the MRs web page at routerlogin.com or 192.168.1.1 in a web browser.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
https://kb.netgear.com/24092/How-do-I-edit-a-reserved-IP-address-entry-on-my-Nighthawk-router
Much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, after checking out the "How do I reserve an IP address," the steps 6, 7 and 8 look a bit daunting. I am unsure on what to select/type in for step 6. There happens to be 13 Address in the Reservation Table. I also see my two satelites and 11 other options which look like my phone, googe home, etc.
I tried holding in the reset button for 15 seconds on all of the devices and the drops have not happened since, fingers crossed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can use what was assigned to the MS by the MR or the last IP address .13 can be changed to something else. Go with what is currently assigned for now to make it easier.
Ok hopefully this will help stablize some.
Should it be ok and continue to work better,
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The main router as well
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
