Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk cm1200 and MR60 router issues. (Router not supported)
Kizzle
Follower
I have both in my house and setup was a breeze. I got them both for my mom and the nighthawk app is saying the MR60 is not supported. It has a picture of a different router in the message that pops up. I followed their instructions to the letter and for some reason it is not working. I am connected to the router via WiFi, it just goes right to it doesn't support it when I try connecting. All help is appreciated
Message 1 of 3
Guru
Re: Nighthawk cm1200 and MR60 router issues. (Router not supported)
Use a wired PC and web browser to setup the MR router.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 826 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
