× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
OpenVPN
Andy1972
OpenVPN
Hi all
I'm a bit stuck with the set-up of the VPN. I followed the instruction of the Nighthawk MR60 manual, but somehow does not get it to work.
As stated above, i'm using MR60 and 1 MS60. Working on a MacBook Pro (early 2015/OS Catalina).
What i did so far:
- enabled the VPN in the Router (checked for all websites and local network)
- enabled DDNS service (and signed up to no IP)
- entered the login details in the DDNS tab of the router
- downloaded the config files (took my hours to find out, that it won't work with language set as "auto")
- installed tunnelblick
- copied the config file (only the config file) into tunnelblick (it worked, but i had to enriched the config file with "remote-cert-tls server"
- Tunnelblick is now running, but i got the message "waiting for server reply). If i change the wifi to my iphone hotspot, i do not have acces to my network
- importing the generated config files in the iphone OpenVPN app generates an parser Error.
Does anyone have a clue what i'm doing wrong? Is there anything else i have to configure/install?
I'm completly new to this. So i might have missed something.
Thanks in advance for your help
Andy
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: OpenVPN
Hi Andy,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 3
Andy1972
Re: OpenVPN
Dear Christian
Yes, i'm in contact with the support. I'm slowly coming closer to a result.
What i found out so far is, that the files generated with the Tab "for non Windows" cannot be used for a mac (they don't have the extension .ovpn. This information was not given by the support, but fount in the internet.
As it is still not running now, they suggest that i open port 1194. As i've never done it, i need to find a friend that can help me. hopefully this will solve all problems 😉
Cheers
Andy
btw, the manual on how to set up the vpn is.... let's say not very accurat
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2002 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
