- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to communicate with some devices on Nighthawk MR60
- Mark as New
- Bookmark
- Subscribe
- Permalink
After trying an Orbi mesh network recently and having connectivity issues I decided to return it and instead give the Nighthawk MR60 mesh system a try instead. It appears to be having its own distinct issues.
I have an HP printer and older chromecast (gen 1 I think). They both work fine when connected to my old router. However, when I connect them to the Nighthawk router they don't appear to be seen by other devices on the network.
I'm able to successfully set up both so they report that they are connected to the wireless network. I can see both of them listed in the routers management page.
However, my PC is unable to see the printer and the chromecast is not visible to other devices on the network either.
I've tried tweaking various settings I've seen suggested in this forum and elsewhere and it hasn't helped.
I've tried chatting with Netgear support, but it was mostly a waste of time. They were suggesting things that seemed totally unrelated. Like disabling SSID broadcasting and changing my 2.4GHz channel. They also suggested told me that devices connected to the router via 2.4GHz would be unable to communicate with devices connected via 5GHz. Which sounds odd.
It's worth mentioning that the printer and chromecast are both connected to the guest network. For a couple reasons. First I was hoping to keep my IoT type devices segmented. Second I want the use WPA3 for the primary network and the printer doesn't support it.
Figured I'd reach out here before resorting to returning yet another device. The community here seemed more knowledgeable than the Netgear support employees last time.
Anyone seen this behavior before? Got any suggestions?
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to communicate with some devices on Nighthawk MR60
Not sure if this would be helpful or not:
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
WIFI 6 PROVIDES FASTER SPEED TO MORE DEVICES AT THE SAME TIME 4 powerful streams deliver up to 1 8Gbps of speed to 25+ devices with reliable performance for streaming HD video gaming or internet surfing and downloads
