× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Want to extend an MR60 Network (Mesh WiFi 6 Router (MR60))
davidbai
Follower
I have had an MR60 with 3 MS60 satellites connected by ethernet as access points for the past 3 years. Gives great coverage but I now want to extend the ethernet and add at least 2 more satellites. What is currently available (Orbis?) that will work will work with this setup?
Message 1 of 3
Accepted Solutions
Guru
Re: Want to extend an MR60 Network (Mesh WiFi 6 Router (MR60))
You can only use the MS60 satellites with that version.
But luckily you can pickup whole renewed kits for cheaper than buying the satellites.
The recommendation is only 3 satellites but you're hardwired, it should be fine.
How many satellites can I add to a Nighthawk Mesh WiFi system? - NETGEAR Support
Message 3 of 3
All Replies
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 973 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
