×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
mk73s
timdey
Follower
mk73s
what is the difference from orbi vs nighthawk? i have an orbi ac1200 and may replace it with the mk73s, will i notice a difference?
Message 1 of 3
Re: mk73s
It probably depends on what you are trying to do with them.
Try reading their data sheets.
Visit the support pages:
Support | NETGEAR
Feed in the model numbers and check the documentation.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Guru
Re: mk73s
Any of the Orbi AC1200's are dual band. The MK73 system is a dual band system as well. if you were going to upgrade, I'd upgrade a triband system unless you're using a hardwired backhaul.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 422 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
