Mynana
Aug 12, 2019Aspirant
How to install Ex7000
How do I install the EX7000 in another room in my home. My main router is the Nighthawk
x6 ModelR8000.
1 Reply
- DarrenMSr. NETGEAR Moderator
You would want to follow the setup instructions and set the extender up in the same room as the router after you set it all up then you can move it to where you want.
DarrenM
