Reply
100Mbps internet speed should I turn on QoS?
alexooitt
Dear all, I need an advise, which I recently upgrade to fiber internet with 100Mbps speed, now shall I turn off my QoS? or just leave it On?.. please help. B/Regards...Alex Ooi
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 4
Accepted Solutions
SScandy
Luminary
Re: 100Mbps internet speed should I turn on QoS?
I also have 100Mbps download speed and I have found that I get better results with it turned off. Depending on your setup, your devices, and what you are trying to do on the internet and your internal network, your results could be totally different than mine. Some have reported that turning QoS on throttles some of their connections so that they end up being slower than with QoS turned off.
I would advise you to just simply try it both ways and see what works better for you.
Message 4 of 4
All Replies
microchip8
Master
If you have less than 300 Mbps, QoS can be beneficial. But it also depends on your use pattern
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 4
@alexooitt
My suggestion would be to turn it off, but its entirely up you.  As @microchip8 stated, usage patterns come into play.
We were just discussing this in another thread.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 3 of 4
SScandy
Luminary
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1813 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
