Reply
2.4 GHz / 5 Ghz channel problem
Marc-AQ
Follower
Hi,
After using the R7000 router for some days without having a problem, a problem came up. Without upgrades / configurations, the router did chanced the channel 6 from 2.4 GHz band to 40(P)+36(S). Im not beable anymore to chance to any channel at the 2.4 Ghz and the 5Ghz band. The 5 Ghz band displaying strange figures, not showing any channel at all
SSID 2.4 Ghz is be able to find but only on the 5Ghz band (40(P)+36(S) ) - 52000Mhz
SSID 5 Ghz is not be able to find at any device, ( wifi analyzer ) channel missing
I did reboot several times, factory reset several times, installed new firmware again
I hope you can help me with a solution, from Netgear custormer support i lose only time ..
thnx in advance
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
fengzhizhi
Re: 2.4 GHz / 5 Ghz channel problem
Same problem here. Have been using R7000 for  3 years, and suddenly found the 5GHz SSID disappeared from the list on all my devices. And the channel for 2.4GHz became 40(P)+36(S), and none for 5GHz when logged onto the router.
Have you got a solution for this issue?
Message 2 of 4
antinode
Guru
> [...] The 5 Ghz band displaying strange figures, not showing any
> channel at all
   I know nothing, but there's a similar report for an R6900P
(V1.0.1.14_1.0.59, if I read the picture correctly):
      https://community.netgear.com/t5/x/x/m-p/1348892
   As usual, reports which include the firmware version might be more
useful than those without.
Message 3 of 4
William10a
Master
> channel at all
Were the firmware update on any of the routers when it happen?
Stange the channels 36+40 would show up on the 2.4 ghz band which should limited to the mid teens channels depending on the country your are in and the 36+40 would the lower scale of the 5ghz band channels the only way would a error in the firmware controlling the routers radios.
What happens if you did a reset of the router and set it up?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1230 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
