Reply
2.4 ghz wifi problem on R8500 after new firmware 1.0.2.64
cwong
Updated R8500 to latest firmware 1.0.2.64, since then 2.4 wifi would not connect.  2.4 would show up on Wifi Analytics, but nothing 2.4 would connect to it.  5ghz works fine.  Router was reset after firmware update.  Got tired to trying to figure out what's going on.  Reverted back to 1.0.2.54, reset and 2.4 ghz works fine.
Anyone else have this problem?
Thanks.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 3
Accepted Solutions
cwong
Re: 2.4 ghz wifi problem on R8500 after new firmware 1.0.2.64
Oh.  Well seems like the firmware isn't the issue.  The 2.4 wifi just died again.
Message 2 of 3
All Replies
cwong
Message 2 of 3
Wetpaws
R8500 Firmware Version 1.0.2.64 causing problems. My router was loosing Internet connection every 1 to 2 hours I reinstalled  Old Firmware
R8500 Firmware Version 1.0.2.30 no more loss of internt from my ISP I hope they fix this new problem
Message 3 of 3
Discussion stats
  • 2 replies
  • 3278 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
