- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2.4G wireless network down after firmware update V1.0.9.34_10.2.36
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi,
I don't know why, but my 2,4Ghz wirless network is down and it's impossible to correct this.
Does anyone have a solution to this problem ?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: 2.4G wireless network down after firmware update V1.0.9.34_10.2.36
How do you know it is down?
What does the LED on the top show?
What does ATTACHED DEVICES or NETWORK MAP show?
You are using SMART CONNECT, is it possible all devices are dual band and will usually connect to the 5Ghz band automatically.
Have you disabled SMART CONNECT and tested to see if this fixes it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for reply 😉
How do you know it is down ?
See the screen capture in the first post, the 2,4G network had a red cross, not the 5G
LED 2,4 OFF / LED 5 ON
Nothing special, all devices that can connect in 5G are present
Yes i try, but the 2,4G was still OFF
In fact what happens and to explain better is that I have a SONY HAP-S1 amplifier and when I want to connect to the SSID is broadcast, and my amplifier does not see it. While it worked very well before the update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Sorry, I did miss the RED CROSS...
OK, the Sony I assume can ONLY connect to the 2.4Ghz band... and that too confirms it is not present.
In settings, IS it ENABLED for Broadcast? Set the Security to NONE as well to be sure it can be connected too.
That LED being off could indicate a problem though, best contact NG support but before that I'd test and restore the old firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks again for your answers
I just found in the many parameters.... yeeeessss !
I went to Advanced Setup -> Wireless Settings -> Advanced Wireless Settings (2.4GHz b / g / n) -> Enable Wireless Network
And there, my amplifier see my SSID and I was able to connect again
Cordialy
User | Count |
11 | |
10 | |
6 | |
3 | |
3 |
