Reply
200 mbps directly from NightHawk GS3000 and only 90 mbps thru NETGEAR GS308 SWITCH
techristian
Initiate
So since I just bought this new NETGEAR GS3000 NightHawk , I figured that I would get a NETGEAR SWITCH to go with it. I bought the GS308 but it isn't passing through the same speed as it is receiving. It is SUPPOSED to be a gigabit switch. The box says forwarding rate of 1000mbps for each port and 16Gbps overall, but this switch clearly can't perform as advertised.
I only have A SINGLE DEVICE PLUGGED INTO THE SWITCH.  One cable to the router, the other cable to my computer.
SWITCH IN 90 MBPS
2 secons later .......DIRECTLY TO ROUTER 200MBPS
And what is this for? A secret feature?WHAT IS THIS FOR ?WHAT IS THIS FOR ?
I uploaded a picture here of the HOLE on the back with the PADLOCK symbol , but alas, it has disappeared.
DAN
Model: GS308|8 ports gigabits unmanaged switch
Message 1 of 7
Accepted Solutions
Guru
Re: 200 mbps directly from NightHawk GS3000 and only 90 mbps thru NETGEAR GS308 SWITCH
Try swapping out cables. A sketchy cat 5e cable can sometimes cause the connection to be 10/100mbps and not gigabit.
Either make sure its a quality cat 5e or cat 6 cable.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 7
All Replies
Guru
Message 2 of 7
antinode
Guru
> SWITCH IN 90 MBPS
> Try swapping out cables. [...]
   Test or swap.  All eight conductors in the cable are needed for
gigabit/s speed; only (the right) four are needed for 100Mb/s (or less).
   In-line images must be approved by a moderator before others can see
them.  The time required varies.  Attachments have no such limitation.
Of course, attachments have their own one-per-message limitation.
   Assuming that your picture agrees with the picture in the product
literature, I'd guess that it's an attachment point for a
theft-prevention device.
Message 3 of 7
techristian
Initiate
I just crimped a new "cat 6" cable. It is only 2-3 feet long. Yes it works at full speed. I was a little nervous. Amazon said it was "cat6" but there were no markings on the cable.
Next I will need to upgrade all of my speed critical cables here.
Thanks
Dan
Message 4 of 7
antinode
Guru
   I'd replace defective cables, if you can find any.  The usual "cable"
problem is a defective connector attachement, not an actual cable
problem.
Message 5 of 7
DAN
Look for "Kensington lock" in the manual.
It is a standard feature on a lot of kit.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 6 of 7
antinode
Guru
   You first?  In exactly which "the manual" did you find that
information?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 382 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
