- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
200 mbps to 100mbps MR60 night hawk ax1600
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 200 mbps to 100mbps MR60 night hawk ax1600
Are you testing over the 2.4ghz or the 5ghz?
2.4ghz is a much slower network than 5ghz.
And the MR systems do band steering so its not something you can just "choose" to be on the 5ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
what wired speed do you get from the router?
What speeds do you get over 2.4ghz?
What modem is it connected to?
Have you checked its internet connection statistics to see if its connecting at gigabit speeds?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
What speeds do you get over 2.4ghz? i dont have device to check
What modem is it connected to? direct from ISP (ACT) india 250 MBPS
Have you checked its internet connection statistics to see if its connecting at gigabit speeds? pic attached
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your statistics are showing your only connecting at 10/100mbs speeds from gateway----router.
Try replacing the ethernet cable with a high quality cat 6 cable. I've seen sketchy cat 5E not connect at gigabit speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
