- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The control you shown this has not fixed anything - as it does not change anything on the router configuration.
We're always keen to learn however.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
Help us out here with a bit more information.
What Netgear hardware is this?
What are you using to connect to the 5GHz wifi?
Apologies for the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
Netgear81 Netgear81
@Auroradawn wrote:
The model number is 28743565.
That is not the model number. Your picture cuts off the bit that shows the model number.
Netgear81 is the SSID, the wifi source that you should connect to, using the password in the slot underneath it.
Is that what you are using when you get the "WiFi is out of range" message?
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
The CM400 in tour footer is a cable modem. It does not do wifi.
I repeat, what is the model number of your router?
It should begin with an R and look something like RXXXX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
@Auroradawn wrote:
It says that the WiFi is out of range when it is located right underneath my android box
This reads like a bad idea, for thermal reasons, for interference reasons, ... you might want to consider an Ethernet connection instead.
@Auroradawn wrote:
Why is it that when I select my 5G it says it is out of range...
Unclear and vague. Does this Android box list the 5G network name on air, or are you trying to connect it to a stored connection profile, ...? Depending on the age and source of this Android box, it might be unable to work on the channels currently operational on your router - for example if one or the other was designed and designated to work under a different regulatory domain.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
And the Android box is ...?
Can you see and connect the router 5G network from other devices, e.g. a mobile phone?
What do you see on this Android box? A photo might help to understand your question a little bit better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
Not up to speed, but no so long ago the Fire TV and Firestick clients had no support for the DFS channels https://www.amazonforum.com/forums/devices/fire-tv/466853-fire-stick-cant-find-5g-wifi
For the Bravia, similar limitations might apply ... if really located just above -> BRAVIA TV Support: How to connect the TV to a network using a wired connection
If you are located in the US, you might try to change change the router to channels 36-48 or 149-165 - these are the only non-DFS channels under FCC regulatory.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
@Auroradawn wrote:
The channels only goes to 11
You are looking at the 2.4 GHz interface .... head over to the 5 GHz one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
11? That is the 2.4Ghz area. 5Ghz is 36 - 48 by 4's or for a 2nd band on some routers for 5Ghz 149 -161 by 4's
Seems you do not have the 5Ghz on by any chance?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
You have to swipe right to see the next page. Should see 2 'dots' on the bottom indicating 2 pages.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
So far you have mentiponed R6700v2 and R6700. They are not the same. Diofferent hatrdware that needs different firwnmare.
@Auroradawn wrote:
My router channel only goes up to 11
That is a channel for 2.4 GHz wifi, as @schumaku says. It has nothing to do with 5 GHz wifi.
Any devices you own that don't support 5 GHz will see only the 2.4 GHz.
We still do not know what you are trying to connect to what. Unless you have changed it, they need to connect to a wifi source that has the Netgear81 SSID shown on the label on your router.
you can feed in the model number, pick the one you own, and find all the documentation for your hardware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
To my knowledge, the Nighthawk App does not offer any control over the wireless channels why ever.
Use the router Web UI (the web based Genie) ideally, e.g. via http://routerlogin.net
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 28743565
