Orbi WiFi 7 RBE973
Reply
2CB05DAB9BE1
Shragin
2CB05DAB9BE1
Hi,
I am trying to find out what speed my router is capable of.
Thank you very much in advance for your help.
Message 1 of 5
antinode
Guru
Re: 2CB05DAB9BE1
   I'm trying to imagine what your (unspecified) "my router" might be.
Look for "Model" on the product label.
   With that datum in hand, you might try this radical concept:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get some.  Read.
> 2CB05DAB9BE1
   What's that, a MAC address?  Not useful to me.
Message 2 of 5
Shragin
Re: 2CB05DAB9BE1
Thank you very much for your reply.
Could WNR2000 be the model number?
Thanks again.
Message 3 of 5
antinode
Guru
Re: 2CB05DAB9BE1
   It could, but there were different "vX" suffixes for different
hardware versions.
   Did you?  Did it say "WNR2000" or "WNR2000v5", or what?
Message 4 of 5
Re: 2CB05DAB9BE1
Whatever the hardware version, from V1 to V5 there is a speed limit on the local network. That's down the hardware.
According to Netgear's manual for these devices, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer Internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
The wifi does not support 5 GHz wifi either.
Nothing wrong with it being old, just don't expect too much.
As to your question, just asking about speed doesn't mean much without an explanation of what you want to do.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 400 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
