Reply
3 Ps4's issues frequent disconnects from game servers?
I am currently using the R700 AC1900 router and am having connectivity issues, specifically in the game For Honor with three Ps4's. If all 3 consoles are on the game at the same time, two of the consoles will disconnect from the game at the same time after about 5 minutes. However, the thing is the in-game settings show an open NAT type for all three consoles.
I have a cable modem bridged (Motorola surfboard) to the R700, I have NAT filtering set to open and upnp on, all three consoles are connected to the router through internet.
Any ideas on how to fix this?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Re: 3 Ps4's issues frequent disconnects from game servers?
Bump?
Message 2 of 4
DarrenM
Sr. NETGEAR Moderator
you may want to try and port forward these ports
  • TCP: 1935,3478-3480
  • UDP: 3074,3478-3479
DarrenM
Message 3 of 4
Unfortunately, you can only forward those ports to one console, so that wouldn't fix my issue. I did end up buying the XR500 and that seems to have fixed the issue, something about the R7000 still not able to achieve a full cone NAT with nat filtering set to open with UPnP on but the XR500 is able too achieve the this.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1081 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
