Orbi WiFi 7 RBE973
Reply
5 GHz worked out of the box, but not soon after
ZTCL
After over one hour on hold with tech support, help please! I have seen several posts about 5 GHz not working, those solutions such as enable wireless radio have not worked for me.  When I first set up the router I saw the 2.4 GHz, 5 GHz, and 2.4 GHz guest networks immediately.  I went thru the set up, which included a firmware update and setting up as an access point, however at some point soon after I noticed I no longer saw the 5 GHz on any of my devices. I went into look at the settings thru my browser and everything looks correct, with the exception of  under Advanced > Wireless Settings (5GHz) has a red X instead of a green check, as the the 5 G guest network wireless settings.  Under the channels field there are four boxes, not channel numbers.  The channel is set to 153, there is no autochannel setting as there is for the 2.4 G settings.
Smart Connect is not enabled.
Nighthawk R6900P AC1900 SMart Wifi Firmware Version V1.0.0.58_1.0.50
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
Accepted Solutions
ZTCL
Re: 5 GHz worked out of the box, but not soon after
Update - after 2 hours and 9 minutes on the phone, the unit was determined to be defective.  Will look for another option.
Message 2 of 2
All Replies
ZTCL
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2805 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
