Orbi WiFi 7 RBE973
Reply
5ET199BBA0134
steeves
5ET199BBA0134
R6350 — AC1750 Smart WiFi Router Wi-Fi 5 Dual Band Gigabit
I look at spec and I could not find the output power at theses 4 modes (25,50,75&100%)  and the antenna gain on my router.
Can you please share this information,
thank you,
steeves
Message 1 of 6
Guru
Re: 5ET199BBA0134
maybe the reason you're trying to find this out is more beneficial than random questions?
Are you trying to reach a certain distance? Trying to decrease power levels to a certain point?
what exactly is your goal?
Message 2 of 6
steeves
Re: 5ET199BBA0134
i'm currently derisking the use of this router to one of our lab
Message 3 of 6
Guru
Re: 5ET199BBA0134
"derisking"?
What do you think you're actually doing with this by changing broadcast power?
Message 4 of 6
steeves
Re: 5ET199BBA0134
Do you yes or no have anwser to my initial question..? otherwise i will  simply measure  it in one of our facility.
Message 5 of 6
Guru
Re: 5ET199BBA0134
This is the community support forum. Where members of the public help out.
You can look it up through the fcc if you'd like .
https://fccid.io/PY317300390
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1956 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
