- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
5Ghz crashing on R7000P
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm experiencing an issue whereby the 5Ghz wifi band will 'crash' when large downloads or uploads are in progress when using my Netgear Nighthawk R7000P router.
By crashing I mean, all devices will be disconnected. The 5Ghz connection will still be visible but no device can actually connect (they all give connection errors).
The 2.4Ghz band continues to work as normal.
I tried the last three or four firmware versions with no luck.
Here's where things get interesting. Netgear are sending me a new router under RMA.
I've borrowed a Netgear N600 from a friend and exactly the same thing is happening.
Large uploads, 5Ghz wifi band drops, devices get booted from the wifi. Devices can see the network but can't connect.
I'm concerned that this is going to be an ongoing issue. Do I sell the new R7000P when it arrives and go with a different manufacturer next time, or is there something I can do to ensure this doesn't continue happening.
For your info, Wifi signal isn't a factor. There is also no loss in actual internet connection. It's definitely a router issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 5Ghz crashing on R7000P
I'll start with the usual boilperplate questions.
It might help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
Kind of points the finger away from the router. Difficult to tell with so little information about the rest of your network. What wifi clients are involved?
Netgear N600 could mean anything. N600 is a now somewhat ancient wifi technology. Netgear made dozens of N600s over the years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's weird is that the NBN internet service isn't dropping out. The Nighthawk app still shows the full 100mbps / 20mbps download / upload speed.
Yet devices won't connect to the 5Ghz connection at all. IE: the router is refusing connections.
I'm not sure what could be causing that if it isn't the router?
As mentioned it's instigated by high upload/download speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
plugged directly into the Netcomm NBN FTTC box. .
NBN is the devil's plaything.
Even FTTC is a confusing term. They use it to mean different things down under.
It probably doesn't matter, but we still don't know what this N600 might be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The NBN FTTC connection box is this unit:
https://superuser.com/questions/1564393/what-is-a-nbn-fttc-connection-device
I'm more concerned with solving the issue with the Nighthawk R7000P!
