Reply
5ghz band stopped working
Stotan7
Follower
So I have had my R700 a few months and loved it. I have some devices on the 2.4 and those that are compatible on the 5ghz band. Then today all of the devices that were on the 5ghz stopped recognizing it. When I look for wifi connections it doesn't even show up anymore. In heck the settings and it says it's broadcasting, even tried manually entering the name, but nothing works.... any thoughts?
Message 1 of 5
ericnix
Re: 5ghz band stopped working
I'm assuming you've rebooted the router?
Netgear R7000
DD-WRT Kong 24345
overclocked to 1.2 GHz
Message 2 of 5
sky4055
Same issue here, with firmware version V1.0.3.60_1.1.27. Only 5GHz.
But after a reboot, everything works again.
Message 3 of 5
khutula
I have the same issue I have two wn2500RP that now won't connect on the 5G network since the R7000 firmware upgrade.
Message 4 of 5
sky4055
Same issue and same material !
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2716 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
