- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
5ghz connection keeps dropping, 2.4ghz fine. Nighthawk R6900P
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pretty much what the title says. A week or so ago the 5ghz band started having issues and just won't remain stable. I'll be connected to it and then 5 minutes later all the devices connected to it will stop working and drop the connection. Meanwhile, the 2.4ghz band is fine. I've tried everything I could and nothing is working. I've tried turning the router and the modem on and off, I've changed the 5ghz channel, I've changed the SSID and password, I've even factory reset the router and yet I'm still having issues. Another thing to note is that all the lights on the router are lit up white while I'm having these issues. Anything else I can try? At this point I'm ready to just buy a new router to get this over with.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
A couple things i'd try first.
1. reinstall the firmware. If something is corrupt in the firmware, a reset only removes settings. it doesn't overwrite the firmware. By reinstalling the current version, it overwrites the firmware.
2. Downgrade the firmware a version. Maybe there's a bug with the version you're on. Try downgrading 1 version, factory resetting, and then resinstalling the router.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 5ghz connection keeps dropping, 2.4ghz fine. Nighthawk R6900P
Hmm, the 5g band has been stable after reinstalling the firmware but I'm not sure if that was the solution or disabling MU-MIMO in the settings. Either way it seems to be stable now so thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad something helped 🙂
