Magic_The
Apr 01, 2017Aspirant
5ghz wifi band wont work
Hey, i disabled it once, but now i cant re enable it and the 5ghz led is turned off,
I have the latest firmware.
Please help.
Fixed my problem.
- William10aMaster
Magic_The wrote:Hey, i disabled it once, but now i cant re enable it and the 5ghz led is turned off,
Please help.
How did disable the 5ghz band in the gui of router by disabling the wifi signal or no ssid because the wifi button would turn off both the 2.4 and 5ghz bands?
- Magic_TheAspirant
Fixed my problem.
