Reply
tpm1952
Follower
6500 wifi router
Is there a way to turn OFF the DHCP function on this router? I want to use the DHCP routing functioality that is on my ISP,s router instead. With both active I have 2 networks which I do not want.
Can the Netgear WIFI router be configured as Access Point only?
Thanks     Tom
Message 1 of 2
antinode
Guru
Re: 6500 wifi router
> 6500 wifi router
   Huh?  "6500"?  Look for"Model" on the product label.
   What, exactly, is your "the Netgear WIFI router"?
   Typically, visit http://netgear.com/support , put in your actual
model number, and look for Documentation.  Get the User Manual.  Read.
Look for "Access Point".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 122 views
  • 0 kudos
  • 2 in conversation
Announcements
