Reply
AC 1750
monicathornton
Luminary
AC 1750
i have just installed my new wifi router.  Oh my phone i have two different networks and don't know the difference.  One is netgear15 and theother is netgear15-5G.  Can someone explain the difference?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
antinode
Guru
Re: AC 1750
> AC 1750
   "AC1750" is a speed, not a model number.  Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier.  Look at the product label.  I'll assume that this is
accurate:
(But there may be a hardware version ("vX", where X = 2, 3, ...), too.
> [...] One is netgear15 and theother is netgear15-5G.
   The R6700[vX] is a dual-band wireless router, which means that it has
a 2.4GHz radio and a 5GHz radio, and each of these can have its own
SSID.
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for
"Specify Basic WiFi Settings".
Message 2 of 3
Re: AC 1750
Regardless of the Netgear device you are using, Netgear sets up the wifi SSIDs with anm indication of the speed. netgear15 = 2.4 GHz while  netgear15-5G = 5Ghz
Read all about it in the manual for the R6700 somewhere at the end of this link:
>>> R6700 | Product | Support | NETGEAR <<<
That manual is a bit old, and might not have kept up with recent changes thanks to new firmware.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 339 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
