Reply
AC1750/6400v2 no longer broadcasting 2.4/5ghz and SSID not visible from devices
Retired_Member
Not applicable
On all of my devices, my AC1750/6400v2 router is no longer visible and is not broadcasting 2.4/5ghz.  This happened spontaneously. I have restarted my devices, the router, and the modem. Help troubleshooting would be appreciated.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 8
Accepted Solutions
Retired_Member
Not applicable
Re: AC1750/6400v2 no longer broadcasting 2.4/5ghz and SSID not visible from devices
That didn't work and your links weren't helpful.  However, I searched these community forums and found out that pressing the Wifi On/Off button solves the problem. I hope my post is helpful to others!
Message 3 of 8
All Replies
antinode
Guru
      https://community.netgear.com/t5/x/x/m-p/1882907#M152535
> [...] This happened spontaneously. [...]
   Everyone says that.  Some even believe it.  Occasionally, but seldom,
it's true.
> [...] Help troubleshooting would be appreciated.
   Here's a radical concept:
      https://en.wikipedia.org/wiki/RTFM
Message 2 of 8
Retired_Member
Not applicable
Message 3 of 8
antinode
Guru
> That didn't work [...]
   _What_, exactly, "didn't work"?
> [...] and your links weren't helpful. [...]
   I'm impressed that you found the link which led directly to the
suggestion, 'Pay particular attention to the "WiFi On/Off button with
LED".  Did you press it?' unhelpful, and then revealed "that pressing
the Wifi On/Off button solves the problem."  Many people couldn't have
managed that feat.
> [...] I hope my post is helpful to others!
   Many things are possible.
Message 4 of 8
additude
Virtuoso
Putting the ol' O N O F F button to the O N position works everytime....
Message 5 of 8
Retired_Member
Not applicable
I was able to find an answer on another thread within this forum. Thanks.
Message 6 of 8
antinode
Guru
> Your suggested fix was incorrect [...]
   How, exactly?  What's the difference between my suggestion and your
"solution"?
> [...] I was able to find an answer on another threat within this
> forum.
   Thanks for the helpful link.
   Still a mystery.
Message 7 of 8
additude
Virtuoso
antinode,
I'll give you a kudos for "Great Effort" on your part.
Thanks for being here and working as a volunteer helping all these schmucks weasel their way thru even the trivialist of "button pushing methodology" and then, not receiving even a compliment or a thanks.....
I'll say thanks to ya on their behalf....
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2262 views
  • 4 kudos
  • 3 in conversation
Announcements
